V Groove or Serpentine?
Whats is better for a high rpm street car?
  • V Groove
    Votes: 3 37.5%
  • Serpentine
    Votes: 5 62.5%
  • Total voters
    8
Ironracer
Gearhead
Tampa Bay Florida
Hello Everyone,
Its time to change pulleys. I'm running 66 273 a/c pulleys on my 73 340. The overdrive water pulley keeps her cool in Tampa ( 185 at idle, sometimes 190 at a long light, cruise at 180) when I first installed them off my old mill, noticed sparks between wp and crank pulleys. I've also noticed my crank pulley has some run out to it. It's a power steering car, but have a manual box. Definitely losing the original power booster and going to dr diff master. Anyway, time to up the pulleys. Definitely going with CRV Racing. Any pros / cons for serpentine vs V belt
I don't think there's a difference properly set up.
Call Dale I'm starting to lean towards the old school v because I'm about to put the car on a diet. The weather system is setup you got one belt power and the power steering off to crank so you can toss that still keep your alternator setup. the only reason I haven't tossed mine is cuz I like the fact the way I got the belt setup I have two belts on my water pump. But its a hassle getting the right belt for the alt. And with the pulleys, i know it's time to do something with it.
I went with the serpentine set up just for the look. Works great. I have the March pulley set up.
I hate March set ups. Just my opinion but I have installed more of them than most folks id bet. (March stuff is ok quality and their fit is, eh...... kinda ok (some are fu@ked and dont fit).....price wise its middle of the road. Some engines dont allow for true serpentine set ups with their system. They tend to ise belts that are a PITA to find (special order belts) ugh... ) i can probably go on but i wont.
On that note im not a fan of serpentine set ups for a few reasons.
1. Weight. Lots of extra parts required with serpentine set ups
2. Redundancy. You dont get any with a serpentine set up.
3. They dont look right on old cars.
All just my opinion but you did ask for opnions so. ..
I'm going with the v groove i reckon
Fixing something that ain't broke........
Well, the crank pulley has a.bit of run out. Wobbles. So while replacing, may as well upgrade. The factory type steel pulleys are actually a few bucks more than the aluminum ones. And, as I have ac pulleys off a 273, finding an alternator belt is a goat screw .
I had zero issues with pulley run out, alignment, fit or finish. OOTB & onto the engine, running down the Hwy. minutes later.
Twice with March kits I had to put their spacers on the mill to get pulleys aligned and once i had to make all the stand offs in the lathe because the ones in the kit were too short.
Got a set on the Duster in the shop. Supposed to fit with a Fluidamper. Had to shim everything to fit.
I’m used to it. But it still pisses me off I had to do it.
Serpentine can give you greater area of belt contact as well
as a more rigid belt. They can also be tensioned by idlers on top of belt opposite the natural force of the belt wanting to expand off the pulleys. v-belts don't offer that.
You've never seen a tensioner on the back side of a V belt? I've seen a lot of them.
Not really. Are these on stock apps? Most of my cars are newer and the 10 that I've had prior to that that had V-belts didn't have any tensioner cept the adjustable alternator but every ribbed belt I've come across has had a dedicated tensioner on top of the belt. Never tossed a ribbed belt.
Triple V belts on old GMC roots systems.
I prefer coged belts but thats just my taste.
Yeah. A lot of the older Toyotees had setups like that.
