hippy 60
OK Thank's a lot i will try it tomorrow.......yes and the wipers still work. Or use something else to push it in.
What model of 5.2 all models are just certain ones........If you haven't bought the engine yet, see if someone has installed a 5.2L Magnum V-8. They have a much shorter distributor which might clear the hump. If you use EDIS ignition w/ a toothed crank wheel, like many on megasquirt site, you don't need a distributor. Also need an early V-8 steering cross-link and 64-66 oil pan (or dent yours). Some say most 1966's had the V-8 cross-link (even slants). It drops ~1/2" lower.
What about using the 5.2 distb.what about the timing do they have the advance in them or they controlled by the computer,I looked one up and they are shorter but i was wonderin about the advance in them do they even have one......5.2L = 318 cu in. I understand the 5.2L block is interchangeable w/ an earlier 318 block, but has roller lifters. The differences are in components - crank pickup, serpentine belt. I understand you could bolt a 64-66 273 oil pan to a 5.2L, for steering clearance. Not true for a 5.9L (360 cu in) since the aft bearing block hump is larger. With any small-block, you could install a custom 36-1 crank trigger wheel. I did so on my 1965 273, mounting it on the crank pulley, w/ Ford pickup off the water pump bolts. Haven't used it yet. But, to get spark timing, you need a controller (megasquirt, etc).
I got me a 5.2 distb. but how would you make it work don't have anything in it but it would be short enough.THANKSWhat about using the 5.2 distb.what about the timing do they have the advance in them or they controlled by the computer,I looked one up and they are shorter but i was wonderin about the advance in them do they even have one......
Thanks Valiant 63, I done what you said and it went back real easy and have plenty of room without any cutting or anything,And the HEI distributor works fine just wanted to tell you that the only way to fix it and the easiest and thank you again,And if you are on Facebook my name is Jeff Greer i would like to have you as a friend.I put the engine in the car without the distributor in it but I had the distributor whole blocked off or covered up. then I worked on pulling the firewall area back that was intrusive to hitting the distributor and I would test fit it by dropping in distributor in to see how much more I needed to go. Partial bump was still there and wipers still hooked up and worked fine.
No cutting needed. Just push the fire wall back a little bit
63 with a 360 4 speed.QU
