stroker_valiant
The headers did fit good, but slighhtly rub the pitmann and idler arm. I had to tweak the headers a bit. I was slightly unhappy with the ceramic coating of the Dougs, inbetween tubes they were not coated. They had assembled the header, then coated it. A couple of the primary tubes were touching, and they were compression bent at the joints rather than a mandrel bend (if that can even be done on headers?). For my stroker, I wished I would have went bigger than a 1 5/8 primary tube thogh.
