JKrebs
68 GTS
Hi All,
Looking to see if anyone has a procedure for checking valve guide clearance by measuring the end play at the top of the valve. I have a set of X heads that are on the bench. The valves hold a good vacuum and i will be disassembling them for a clean up, some new springs and seals. Just don't know if i need to have the guides done. I feel slight movement when i move the valves from side to side, I can put a gauge on the valves but i have no idea on what is in tolerance. Thanks
