Valve pocket/bowl hog tools....
RustyRatRod
Caput villa stultus
Georgia
Those who do your own cylinder head work, what are you using for valve bowl/pocket hog tools? What's reasonable and won't put me in the poorhouse?
I have an old B&D in great shape and make my own stones out of blanks.
That's sorta the direction I wanna go. I got no problem with stones. As long as they're dressed and the pilots are tight, you'll get a good job. Just right now, I haven't found anything affordable for me. Maybe somethin will come along.
The very reason I like a Dremel. It doesn't gouge all at once like a air grinder
Well, when I say "hand held" I mean electric, air, or "otherwise" powered. lol
Now, put me on something fixed like a drill press or an IDL and I'm good to go.
I have a Souix set, and that what I do, because I don't have a Winona or equivalent guide and seat machine.
But I have to warn you, when you are using one of those slightly tapered stones, they tend to want to seize in the hole, kinda like ball joint stud tapers seize/ lock-up. Boom, the stone explodes. As long as you're wearing safety glasses you should be good, but the first time it happens don't be surprised. Just be patient and don't lean too hard on it.
What I am going to use when I find some reasonable are a couple of properly sized cutters for the bowl. There are sets on ebay here and there that I am looking at.
Brian can you explain what you mean by "make your own" ?
I have knockoff dremel tool, but attachments are friggin pricy. I've checked walmart and limited supply there. Suggestions?
Heres some of what I'm using
Good quality carbide burrs run about $40 each but will last a long time on cast iron if you don't overheat them and chatter them.
I think what he means is that you buy a straight (solid)cylindrical stone of the approx diameter of the inside of your valve seat, then diamond dress it to say 75deg(7.5degrees off of each of the straight sides) until it is a cone shape with the smaller diameter end, the approx size of the bowl throat, and grind away until you're satisfied. I THINK that is what he is referring to.
Yes, Not necessarily hand porting.
I use Dremel stones like the 8193 stone made by Dremel. I don't like air tool cutters because most of the time they gouge too fast.
HF electric die grinder with carbide burrs (mcmaster carr) and router speed control. Dont know that I have much more that $150 into it all.
Make a fixture to hold the head firmly in position. Slant six rocker shaft works and allows it to rotate.
So using the grinding stone as a form cutter to shape the bowl walls by plunge cutting? Yikes! Better be rigidly mounted.
Yep. There's a certain amount of consistency there until the stone wears down and needs dressed.
View attachment 1715348259 View attachment 1715348251 View attachment 1715348252 View attachment 1715348253
It's interesting how stable the 6" long carbides are. I thought they would chatter all over the place. I think you don't force them too much because of their length.
Dont like to disagree mike but i just bought 2 of the long burrs single cut for only 16 bucks each from mc master carr.
Dont like to disagree mike but i just got some from mcmaster good quality ones to, 1 was 16 and 1 was 20.
It is. I would do that no other way than to use the proper fixture that mounts to a pilot that fits into the valve guide. I am also looking at carbide cutters.
Interesting. With the pilot it shouldn't be that bad then. I need to look into a fixture to hold the head on my mill table. I can make any shape form tool I want on the lathe, heat treat it, mount on an arbor and Bob's your uncle. I'd feel a lot more confident about not hosing up a nice valve job trying to do the bowl by hand if I can do it in the mill. Should be able to accomplish it with material on hand. Sounds like a good winter project to get some more flow out of the J heads.
Yep I have the same problem, I put a flat washer then a small spring and another washer under the stone and go at it easy, the spring really helps it from sucking down in.
Even w/a rough stone and a pilot, the bowls aren't uniform, I have carbide pilots that are hard & accurate...but if Your not patient(VERY) the side loading can snap them. That goes for stones and multi-blade/bit cutters, but really for single cutters ie Serdi etc. If You lay out Your dimensions accurately on card sheet, and set the width/height w/markings starting from a guide center-line, You can exacto-cut a template out and insert it in the guide and work with a burr till You're really close. Have You used/seen the ones Mopar sells/sold?
I have a B&D seat and valve grinder, so I buy blank stones and put what ever angle or multiple angles on it to match the pocket I'm doing.
