What percentage of the time are you driving at 5200? or how about 3900? At 3900 the torque loss of the thermostatic clutch-fan was, IIRC, 8 flbs.
8 x3900/5250 = 6hp. I'll gladly accept that 6 hp loss.
>By 30mph,when ram air begins to take over the cooling duty,I wonder just how hard the fan is really working. I mean it has a 30 mph wind in front of it, and the air-temp through the rad has dropped to maybe 150*. The thermostat on the clutch is probably allowing the clutch to slip at or near maximum-slip.
I think at 30mph the horsepower loss might be closer to zero.For me, In first gear this will be 4089rpm; second will be 2527; and third would be 1839. It doesn't have anything to do with rpm anymore.
>At 60 mph Ram air is operating at full capacity and the fan is being propellered by the 60mph wind coming thru the rad. Any clutched fan is going for a free-ride.I mean stick your arm out the window at 60mph and see what happens!
>I can't say what might be happening at the top-end of the track, but since a good bunch of us are in the low 12s, and it's about 6 or 7 seconds from 60mph to 110ish, If I was a betting man, I'd put money on the fan not even needing to be on there, until the return road.
>So, when is that thermostatic clutch fan really costing power, and how much?
My theory is that the fan only costs horsepower below 30ish mph, and if I was stuck in first gear, it would be 6 big fat horsepower, at 3900, somewhere well below 30 mph.
But guess what; I can spin 325DRs on the primaries, so 6 bigfathorsepower means exactly nothing to me.
That's my theory.
K.i.s.s.
if the engine is running, then the fan is spinning. The faster the engine is running, the faster the fan is spinning. And it's all automatic.
And my 35Amp alternator lasts over 20 years.
Oh yeah;I lost a belt once, in 1971.I was 19 and ignorant.
