VR1 oil on sale.---AMAZON
IIRC VR-1 has a high zinc content that is actually not recommended for EFI. I may be mistaking.....Messes up the sniff test.
Ordered 3 cases for 2 oil changes. I should order 10, but it is Xmas time.
I have not heard this before, is it for all EFI's? I am interested in hearing more, because I use the Valvoline VR1 oil
It's not good for the catalytic converter.
Yup, "...The phosphorus in this compound (ZDxx+phosphorous) creates carbon buildup in engine bores and valvetrains, and both compounds can also lead to the early demise of catalytic converters.." . F' em if you dont run cats and change your oil regularly! :icon_fU:
Make sure you know it may not be delivered right away. That page says usually ships in one to two months.
