Waiting For Response to Question RE: Barracuda Paint Gasket Set ('65)
dibbons
La Paz, B.C.S., Mexico
I should be hearing back from Detroit Muscle Technologies anytime now. I see a notice on their website no more international shipping. I guess I have been lucky, haven't lost anything yet (problems with delays and damage, yes).
Hello, Regarding the ABA6565PK01 1965 Barracuda Paint Gasket Set I have a problem identifying three items in the package, can you please help? The material for all three items seems to be about the same, it's a white-colored foam. Item 1 is two wound up rolls of white foam ribbon, Item 2 is what looks like four white foam large "washers" which are round with a tiny hole in the center, Item number 3 is shaped like a donut round with a large hole in the center. Thank you.
Item 3 I believe goes between the filler neck and quarter panel. From you're previous post, the 2 black plastic spacers go on the rear quarters in the rear where the rear bumper wraps around the quarters. 65'
Yes. That foam appears to go between the roof and the stainless trim that the upper weather strip mounts to.
Aaron
