[WANTED] Wanted: Cragar 09005-4 lug nuts
They are on back order everywhere for the 09005 RH nuts. the 09004 LH nuts are available at almost any big auto parts stores. If it's an emergency you can have them machined out of stainless steel.
The lug nut shank dia is .592 for the 5x4 Cragars the other size is .680. You also need .600 id x 1.0 od washers for the 5x4 bolt pattern.
My question...........would a 15x7- 5 on 4 lug LP -7/16-20 Cragar take a different lug than a
14x7 - 5 on 4 LP - 7/16-20 Cragar?
It depends on how old the Cragars are. The (early) 1960's - 80's rims 5x4 took 09005 RH and 09004 LH .592 dia shank style. The newer rims need a 60 degree conical. Both the (early)14" and 15" 5x4 bolt circle "only" took the .592 shank style.
Here are the specs from Summit on the 14 x7's SBP Cragar's they're selling
Lug Nut Seat Style:
Shank
Lug Nut Shank Length (in.):
0.767 in.
Lug Nut Shank Diameter (in.):
0.592 in.
Hub Centric Ring Compatible:
No
Center Bore Diameter (in.):
2.820 in.
Center Bore Diameter (mm):
71.63mm
The specs on the Cragar 15 x7 SBP Cragar
Lug Nut Seat Style:
Conical seat - 60 degree
No
2.820 in.
71.63mm
