[WANTED] WANTED Early T Bar Adjuster Bolts 9/16-16
Hyper_pak
Old School Chrysler Fan
Desoto Texas
So who knows where these parts walk away to, but they do. I have the steel blocks but I need the 2 bolts to adjust the front T-bars on my 62 Lancer. These are fine tread, not coarse, 9/16 x 16 TPI. Round head to fit into the adjuster socket. Just need to be usable. I have the steel blocks but if you don't want to split them up I will take both. I have a set of big ball joint coarse tread parts I can use, but I want the fine ones if I can find them. Any responses are welcomed. Anyone?
I should have some and can check after I get home from dropping a trans and converter off to Dynamic tomorrow.
