What did I do wrong???
Twisted-72
Oxford PA
Ok so I've been collecting 8 3/4 parts. So thinking I have everything I started to assemble the rear. I have a 489 case with a clutch type sure grip. When I put in the drivers side axle, I ended up with a bit of drag on the axle. The passenger axle when installed doesn't seem to want to go all the way in and if I snug the nuts to the flange it all locks up. I've run the adjuster in and out, with no change. So what did I do wrong ?
ok I read the thread but I'm running all stock parts and the thread is talking about using green bearing and cutting axels. so why is the stock stuff not working?
