T56MaxTorq
Have a 360 short block in the machine shop that I need a pair of heads for and I have a few decisions to make and I would love some help. Going into a 4x4 Ramcharger, want a strong, powerful truck but nothing crazy. At 6200 ft. altitude.
Specs for the short block are:
92 360, 4.030 overbore
Hydraulic Roller Comp Cam, .538 lift, 224/230, 110 LSA
KB Pistons, step-dish quench pad type piston, 19.4 cc vol.
LD340 or Performer RPM or Air Gap
Holley 600 or 650 vac-sec
Head choices are:
1) Magnum Heads I have a pair in the garage, needs stock rebuild with a very mild port/clean-up job. Would need a new cam and springs with 1.6 lift but would retain stock rockers.
2) A set of X-heads off the duster, 2.02 valves, ported w/ roller rockers. Needs valve seals and a set of pretty aluminum heads for the duster to replace. Most expensive route by far, but the duster is set up for high-altitude and I may end up living at a lot lower altitude one day and that could be bad with 11:1 and x heads.
3) A set of 308 Open-Chamber heads I have, but they need new valves, probably 2.02's, CAT or some other cheap 1.5 ratio roller rockers.
4) A set of 302 Closed-Chambered heads from online or the junkyard. 2.02's, intake and exhaust port job to expand the ports to a 360 size intake. I've read this making 400 hp in a 318.
Looking for a 9-9.5ish compression ratio.
Head choices are:
