Have a 62 valiant 225 cu in with automatic, Spotless radiator(flow tested,) and block new water pump and 160 thermostat. after about three miles at 60 or so on a 90 degree day the running temp hits 185-190 never boils over or bangs etc? all belts are tight and airflow clear. Thought this could be a little high. Timing is spot on at 2 1/2 before TDC. Maybe this is normal and maybe not does not effect running or idle ???
