What is this part? 72 Duster 3 speed
=Max Wedge=
Ohio
Hi All,
I'm thinking this might be the flasher "fuse" or "relay" (huge guess) do these parts go bad? (Photo attached) has the rare made in USA on it, other than that no numbers whatsoever. I have turn signal for the LH side but nothing for the RH side. Also, no 4-way flasher2. Working on a 72 duster 3 speed. ANY help would be very much appreciated. P.S. wires going to it are yellow and pink.......
Many Thanks,
MW
That's the delay device for the "key in" switch. Basically a heater that heats up and causes a bi-metal strip to bend. "Sorta" like a flasher only it doesn't cycle.
If you've carefully checked the bulbs and connections at all 4 corners "it might be" the column TS switch. Before you do that I'd disconnect the column switch, look up the wires colors, and jumper power into the connector at the proper wires and see if all the lights properly work.
Go download the factory shop manual for 72 over at MyMopar
