Torrance00
- Joined
- Jan 12, 2010
- Messages
- 119
- Reaction score
- 3
Hello all
Anyone know what this item is for, and is it replaceable?
It's up under the dash and seems to be on the #7 fuse circuit
I have been having problems with that circuit and finally I think I found the culprit
bad connection at the door jam switch, only getting 3-5 volts. replaced the connections
now OK, but this item pinged like a spring came apart.... thought that might have something
to do with a blown fuse in that line...
Part # is 3764548 90393 1684
OK, I open the case and removed the "buzzer" it still works...
Now to trace the wiring. The connection is Red hot (always0 a Black and a Blue wire
exit back into the wiring loom.
the Haynes book does not show two wires, one I would say is a ground... probably black
but not sure right now,
Thanks
Best
Thanks
Best
