What rpm stall converter should use?
I have plenty of both!
I have a 1/2 dozen Street Strip Show
That car held the NHRA National Record in B/S @ 11.12 @ 119
Rules were very strict back then.
It won plenty of money on the street!
I run the Stock Mopar Hydraulic Roller Lifters regularly without issues as
long as lift is not over 550!
If they are used just inspect Roller and Pin Carefully.
I came by your trailer twice once friday and once saturday....said hi to your son but you were no where to be found...
GTX John, I’m new to this to the website, how do I talk to you about those converters?
Click on his screen name and select “Start a Conversation” & a new window pops up.
Enter in a title, then go to the main body and type in your message. Then press “Start a conversation.” AKA Send.
I will be changing out my 904 trans for a 727, do they both use the same trans cross member?
I won a lot of money on the street too with that Road Runner. That was a quick and good running car, I’m glad I bought it from you, but sad after I sold it.
