Treblig
The ease with which you can turn the steering wheel from a stop is greatly determined by the width of the front tires and also by how well they are inflated. The more narrow the tire the easier it is to turn the steering. The more tire pressure you have the easier it turns. So if have wide front tires it's best to get a steering box (manual or power) that can easily overcome the initial turning traction.
One person may be having good results with a certain steering box but the reason may be that he/she has very narrow tires that are inflated well.!! Another person with wide underinflated front tires may be having problems with a particular steering box, but it may not be the steering box's fault!!
PS - Good alignment also helps!!
treblig
treblig
