I must be a lot older than you guys, but I remember a 62 dodge dart 383 with factory dual quads, solid lifter cam , 11 to 1 that ran really well, I have driven these cars and they handle reasonably well and were quite quick....
Based upon 1/4 Mile Elapsed Times, as per Chrysler Performance Technical Staff
#1......1969 440 Cuda' Automatic 440/375 HP w/Special Order 4.10 Gears
In complete stock mode, with E-70 X 14 tires.
A best elapsed time of 13.44 @ 106.55 MPH
Included a performance tune-up and air cleaner removed.
I had my share of 62's they ran but I never had one that would roll hard in the corners. unless a stabilizer was added.I must be a lot older than you guys, but I remember a 62 dodge dart 383 with factory dual quads, solid lifter cam , 11 to 1 that ran really well, I have driven these cars and they handle reasonably well and were quite quick....
BB-Dave,
My 1969 440 Cuda' had 3.55 Gears (as per standard gears), when I got it in 1971.
As per 'option codes', the 3.91 was the only factory option listed. But digging a bit,
it appears that 4.10's could have been ordered, but I'm guessing as a dealer only
installed option.
Chrylser Performace was able to get that 440 Cuda' down to 13.19 @ 109.10 MPH
by installing a set of 7" M & H Racemaster slicks, mounted on specially made 15" x 5.5"
steel rims with the 4" bolt pattern.
In fear that the 440 would rip the drivetrain apart??? are you serious?? that is the most absurd comment I have read all day. Your should have told Chrysler that when they installed hemis and 4 speeds in the 68 SS cars.The 1969,
440 Cuda and 440 Dart, were specifically built with C/SA in mind for 1969.
C/SA = 8.50 - 8.99 Wt/Hp or SS/GA
The #3310 lb. Fastack 440 Cuda' had a very nice 8.82 Wt/Hp.
Chrysler Performance never had any intentions of putting a 4-Speed in
the car, in fear that the 440 would rip apart the drivetrain in 'violent' off
the line launches.
When did they do this?
I know enough about the Chrysler go-fast guys to expect that it probably had a few hidden tricks. Like how "stock" was the 440?
IIRC, the magazines of the day had the 440 M codes running low 14's. I assumed this thread would be about cars that theoretically just rolled out of the dealership with maybe some break-in miles.
I talk to a local guy who owns an almost perfectly restored 440 FB but he won't run it on the strip at all because of the E70x14 tires and the drum brakes scare him. (maybe the value is an influence too) He has a couple other well known 69 cudas that are modified.
Kosmic, i didn't post the part you quoted......"69 cuda 440" did. I never heard what he posted either??? He had his M-cuda in '71 and i was only 8 years old........so i'll have to believe him! I can only WISH i was his age so i too could have been old enough to drive in the heat of the muscle car era!!! LOL
But they DID put 440/ 4 speed combos in B bodies... which are heavier cars, so your logic still doesnt make alot of sense to me!
