LXguy
but in your honest opinion, you havent really said if you think she'll hold up...whats your opinion on that- coming from a mustang guy? you think it'll hold or it'll crap out...
Barring any preexisting conditions with the trans (previous owner abused it. etc) I think if you set it up right, I think there's a really good chance it'll last quite a while. Make sure the clutch is right, use good fluid, etc.
My '95 Cobra was at about the level I'm guessing your 340 will be. I made a lot of passes with a stock trans and clutch and that pig weighed 3600 lbs with me in it. I broke the stock carrier and never had problems with the trans.
I've had much better luck with those transmissions than their reputation would indicate, but I have broken a lot of stuff learning about clutches and fluid and crap.
I think everyone who rocks a T-5 should probably have a spare, and should learn how to work on them. It's not that hard (you only need a press for one bearing), and if you do tear them up, you'll save a TON of money in no time by doing your own work.
