What wire is this
joemoy29
NJ
Just putting my harness back in the car and I have a blue wire not tapp d in the harness with a factory termination by the rear passenger valve cover. What is this for
I would download the diagram but I use my iPhone for everything and can open a zip file
Thanks joe
Lol sorry guys long day. It's a 70 dart. Can get a pic tomorrow but there is only three wires in the area one for the on black ground. One grey for oil light and this blue one which has a much longer lead. Choke does make sense
Blue is also coil. What engine?
It's a 318 harness. The blower motor dosent have wires in the engine at correct? Coil is a good point forgot about that. I will take a pic in the am sorry should have done that first
Is it a spade type connector or ring? Spade lends to choke for sure!
Might be the heater blower motor power?
I agree with trailbeast that it may be the blower motor power lead...
Here are the pics. The brown wire by the blue is that a ground or for coil?
You Need a wiring diagram of your engine compartment. They are in the fac service manuals. But my take on that long blue wire with that kind of connector is......... its for your stock temp sender.
barracudadave67
Thats what I thought too, but, in this pic, you can see the temp connector right next to the thermo housing....
It's either for the idle solenoid.........or a well choke heater?
