Whats missing between these lines????? Help needed!!!
31pickemup
Ohio
Hey Gang
I'm in the process of putting brake lines on my 67 'S'. The car has disc brakes but no booster. My question is what goes between these two lines? This is a couple of feet behind the brake junction block on the drivers side. Here is a picture. Any clue?
Looks like you just need a coupling. Should be a home run to the rubber hose to the axle.Maybe the after market is two peices in case you want to install an adjustable proportioning valve.
How bout "Fine Lines"?? Or "The Right Stuff", either may have it!! A donor car with disc would surely have it if you can find one!! Geof
Call the right stuff detailing. P/N RMB6801. $39 in their catalogue. Theirs have been tested to pass fluid. many on the market dont pass brake fluid. 1-800-405-2000 and ask for Bear.
Proporting valve, you can buy a repo or an adjustable one from Summit or Jegs.
It is actually called the rear hold off valve. Its purpose is to delay the rear brakes from activating prior to the front discs hitting. Inline tubes sells them as well.
