Wheel Well Splash Shield??
1966DartConvertible
Malaysia
Hi there, Im sure im missing something here...
LOOK MA! I can see the front TIRES...
Is there suppose to be some sort of a splash shield here?
If so, can someone take a picture of your front wheel well and post it here?
Thanks
Syed
Yes, you are missing the inner splash shields. They go from top to bottom with a small rubber moulding to the fender side. I will shoot a picture for you when I get back home. I think I also have those two for you!
The early models had stamped metal shields with rubber seals . The last couple of year models had all molded plastic shields.
This is how they look. These ones have most of the side rubber strip left too. The top rubber flap is in great shape. They are rust free and I have a set of screws for it too.
