Where to get a steering "rag joint"?????
dustoff440
central fl
Im referring to the metal/ rubber biscuit at the end of the steering shaft that attaches to the steering. I cant seem to find one???
Scuba0331:
The rebuild kit is only $30 at Steer and Gear. What's cool about this is that you slip the boot over the coupler unlike the original were you have to crimp the piece of metal over the boot.
I installed one of those rubber boots last spring during a steering box replacement, it allows grease to ooze out from coupler making a mess.
I will be installing the factory stile seal this winter in hopes of keeping the grease where it belongs.
http://www.steerandgear.com/Chrysler_Catalog.html#TXTOBJ7DB1219F302938E1
Good job!! Looks like the number 2112 which is a 30 dollar rebuild kit is the one for me. I could get by on the one I have but I cant see putting an old rubber joint on when everything else steering wise has been replaced or reconditioned except the steering box which was replaced about 30k ago.
