which intakes fit under a 1969 Barracuda hood with a 440?
braz28
qc
installing a hood scoop or a stock iron intake is not an option. researching which aluminium intakes can be installed on a 440 under a stock 1969 Barracuda hood, even better if i could retain stock air cleaner.
thanks in advance
A stock six-barrel setup will fit under a stock hood!
I run a Holley Street Dominator, pretty good intake for pretty wide range of builds. No clearance issues, my Eddy RPM gets pretty tight and required a drop base air cleaner.
