Cevidicus
CevidiGrinch
Hey FABO crew.
Is a V-8 k-member required for a 5.7 swap? Will a 72 /6 k-frame work with the TTi conversion mounts? Would a spool mount '73 up /6 k member be better than the '72 style? I have access to one on the cheap.
I am not sure what the differance is between /6 and V8 K's. I've read that a V-8 K frame is needed but want to confirm.
Which is suggested for a /6 to 5.7 conversion? Either way, I plan on some structural bracing and reinforcement.
What do you folks think? What have you done?
Thanks,
CM
Thanks,
CM
