Who can recommend a good Freon A/C electronic leak detector?
dibbons
La Paz, B.C.S., Mexico
I have three cars with A/C and it seems either one or the other is always needing an A/C recharge. Time to bite the bullet and purchase my very own 134A leak detector. I see a brand "Robinair" on Amazon, but I thought I better check with the guys (general term for both boys and girls) to see what experience others have had with the Robinair and any other brands. For a little over a hundred bucks, I think it would be worth it. Thank you.
I never had any real luck with ANY of the electronic sniffers....I have had better luck with the dye you inject, and inspect with a light....just my 2 cents
Many different types of leak detectors out there, and they all have pros and cons.
These are my opinions:
Best electronic H-10 Bacharach - H-10 PRO Refrigerant Leak Detector
expensive, and too sensitive to pinpoint large leaks
Soap solution (dawn and windshield washer fluid 50/50, in a spray bottle. Cheap and actually pretty good at finding leaks in areas you can spray. But large leaks can blow the bubbles away.
Ultrasonic detector, not too expensive, but can "hear" leaks to pinpoint them. Can also be used to pinpoint wind noise leaks.
https://www.amazon.com/dp/B000NI2BD8/?tag=joeychgo-20
Floresent Dye can find small leaks, or leaks that only leak when the system is running, but sometimes may take a day or so to show up the leak, and can be difficult to find evaporator leaks.
Also the old "propane torch" detector for R-12 (never tried it on r-134a)
I use a combination of all of these. In your case for your own vehicles, where you have the vehicle all the time, and can wait, use the dye and/or the soap solution.
Robinair is a well known name in the HVAC industry
What I used with my '05 Impala. I guess I got lucky cause it was the condenser in front of the radiator. But the light worked really well.
