Ok, the black wire on the steering wheel does not have any power going to it, so that must be the most likely culprit
I took the wheel off and there is no power to the black wire with the wheel on it, so I will have to trace that one back
As far as the diagram, it looks like my relay only has 3 wire for the horn, plus one for the buzzer
No wire for a keyed source going to the horn
basic horn operation.
to power the horn
- constant on power source to the horn relay (Older cars its mounted under the hood and is tapped off the alt wiring.) your car I'm not sure where it gets its constant feed from
- from the switched side of the horn relay power goes to the horns then through the horn mechanism and to ground.
to switch the relay on and off
- The other post (of the 3 for the horn relay) runs to the steering column then to the horn switch
- the horn switch grounds out the wire causing the relay to energize.
The colors ARE NOT representative of your cars wiring just representing 12V and grounding (note BLACK and GREEN are not Ground on our cars
your car has the buzzer and relay in one and under the dash so the pinout of the relay buzzer is different but this is how it all works
Your 71 from the FSM
operation:
Horn
"+12V" always on from the battery OR main splice etc.
"Horn Switch" when you press on the horn switch it closes the NO (Normally Open) contact and makes a path to ground.
"To Horn Switch" gets the ground from the "Horn Switch" so the coil will energies and close the NO "To Horns" contact
"To Horns" now provides 12V to make the horns sound
Key-in Buzzer
IF the key is in the ignition the NO "Key Switch" passes the ground to the NC (Normally Closed) contact in the relay
This provides a ground to energies the coil in the relay.
The coil will energies and close the NO "To Horns" contact
The "To Horns" NO contact now provides 12V to make the horns sound
BUT at the same time the "To Horns" NO contact closes the NC contact in the relay opens and the horn makes one beep rather than stay on continuously
H3-20BK* (black from horn switch, grounding energizes the horn relay)
H2-16DGN/R* (dark green with red trace, provides 12V to the horns when the horn switch is pressed and the horn relay is energized)
H1-16 V (violet, constant on 12v (might go through a fuse?)
M16-20BK (black, makes a ground if the key is in the ignition and the door is opened)
MYMOPAR.COM download free your cars factory service manual and or the wiring diagrams available. and start tracing things. YOU MUST know this stuff if you are going to work on your classic car.
CLASSICCARWIRING.COM great source for laminated full color diagrams (best $25.00 I ever spent)
