Max10
Member
I know you can move a manual vehicle a short distnace under starter power alone. Can the same be done with a push button slant 6? if I put it in drive or reverse and crank, it cranks, but no movement occurs.
No, but the PB trans can be push started/coast started, because of the rear pump driven by the output shaft.....something the later trannys do not have, so there's that.LOL at some of the responses. The more you know, as they used to say on TV.
Neutral safety switch isn't working.
