Will a Stock 489 handle 700hp?
Have you had a stock 8.75, 489 hold up to 700hp while racing?
  • Yes
    Votes: 11 27.5%
  • No
    Votes: 29 72.5%
  • Total voters
    40
Well I ran a 489 case with a spool 4.88 gears in a 8 3/4 in a 71 Scamp for 4 seasons and never broke it. Car ran 6.30’s would 60’ in the 1.35-1.40 with 4500 converter and trans brake. Ran 29.5 11.5x 15. It would hook so hard the housing dented the shocks from axle wrap. Had to use adjustable snubber to prevent that. Also had 002/003 SS springs. Guess I was just lucky eh?
I have about a 650hp 408 H.P. that has a H.P. 727 behind it 2,500 stall. It is time to put a diff in. Some people are telling me a stock 489 8.75, with stock gears, race axles, stock pinion yoke, stock bearings, etc, will handle 700hp with an Automatic Trans.
Some people are telling me I need this pumpkin for it:
Mopar 8 3/4" (8.75) 489 Case Third Member
I want the green bearings, a 3:23 ratio, 6 Helical Gear Sure Track II, w/a 1350 Yoke.
Problem is I can get a stock pumpkin for $850, while the race pumpkin with the above features is $1,425. Don't get me wrong, I am not out to pinch penny. What I don't want to do is spend the money on a race pumpkin when a stock one will do. If the stock will not do, I will definitely buy the race pumpkin. No Problemo! I have heard a lot of different answers.
Members who have experimented in this area will prove most helpful. I need to know what your experience was.
It wont last if you make it hook up , but you wont with 323`s anyway ------------
Where did you get your $1,200 Dana??? Dr Diff and Strange want like 2X that... Yikes!
I like detroit lockers for street n strip-----------dana 60 all the way .
When u blow an 8 3/4 every other week end , you`ll learn.
@70DusterBob, he built it from a truck dana, probably started with a core, for around $250, then had it narrowed, new axle ends, custom axles, and a suregrip, or spool, around 800 in parts, and a couple hundred in labor. For guys that can do their own narrowing/welding, i have heard of danas done for under a grand.
Given the choice of carrier go with the power lock not the track lock. Power lock has the clutches with two cross shafts. Trac-lok has clutches with 1 shaft
I run 742 carriers 456 430' and 488's with spools and GM style yoke. Slick tire with over 700 HP All those old B-body Hemi's and Max wedges ran 742's wheels in the air from 62-66. There were no Dana's .
I never did care for 489 carriers, They were as good as the cone style sure grips they came with from 69 -72. The only reason I would use a 489 would be to make a muscle car come with what they had. Remember most of them came with F70 14 bias tires.
The first 8 3/4 rear I scattered was a 489. I have not broke a 742 to this day. 741's the pinions break with slicks. My first choice of a rear would be a Ford 9 inch. Three pinion bearings. one behind the yoke, One in front of the pinion gear and one behind the pinion gear. Pinion flex is the weak link that makes them break if they are not set up right. The teeth need to engage deep. I have several chunks as spares so I am staying with what I have 8 3/4, easy gear swap for 275-315 class 1/4 -1/8 mile. who can carry spare Dana's in the race trailer.
Billet caps
good axles
good gear sets
GM style yoke
Proper pinion angle
good stiff front segment springs
Less reciprocating weight then the Dana.
This is just my opinion for spending as least as possible and going racing with a 3650 lb automatic car with a 5500 stall. Same rear since the car was built many many years ago. And it will carry the wheels if wanted.
Actually thinking back I’m sure it was a 742 case as I usually don’t use a 489.
For what its worth, I run a 742 3rd member in my MO875 (8 3/4) housing with 35 spline axles and a spool, foot braking at the track in my 3250lbs car and it holds up fine (runs low 10's). I also drive it all over town with my 5000 rpm converter and 4.10 gears. If built right it works just fine.
.....BUT, if I were you (with the power that you think you might have), I would either go with a Dana, or a Ford 9 inch. I would probably lean toward the 9 inch because there is a better selection of gears.
First thing you need to do is get out of that where can I run down and buy one mind frame...
I watched Craigslist till what I was looking for a popped up. It was a Dana 60 heavy duty out of a Dodge truck. It had 410 gears and was in excellent condition, for $160... I kept the 410 gears and sold the axles drums brakes and open carrier for a small sum of $40 to get it out of my garage and get it into the hands of someone who can use it.. now I'm $120 into an axle end gears..
https://seattle.craigslist.org/kit/pts/d/poulsbo-dana-rear-axle/7212731488.html
^^^that's just a super quick two-minute search for the first thing I found but again I did a little bit more research and waited for the time to be right..
So add to that $120 a call to Dr Dif (Cass) for $75 Mopar 8 3/4 style housing ends, a spool to put my gears on for a $125, $50 for new carrier bearings, $300 for 35-spline axles with green bearings and 3 inch studs, I think $25 for thepads for the leaf springs to weld to the rear end, $300 to have the ends and the pads welded on professionally and $175 to have the gear setup...
Oops I lied it's $1200 and $5 LOL...
View attachment 1715615610 View attachment 1715615614
And if you need backing plates you can just get them off of a Dakota truck with an 8 1/4. You can probably get the drums and all that stuff as well...
Kind of irrelevant but goes along the theme of what everyone has been saying... my stock rv 360 with aluminum intake and headers backed by a stockish 727 has yet to kill my 7 1/4 behind it... a rear end that has a reputation of breaking if you look at it wrong. I keep small tires on it and give it hell and it has lived for the couple thousand miles that Ive driven it (and an unknown amount of miles put on by the previous owner). Point is, on the street with no sticky tires that 8.75 should live for a LONG time, but once you start giving it big system shocks and hard launches with stickys, then you will find the weak links quickly.
That being said, plenty of guys have made their 8.75s live long lives behind race dedicated cars once they got rid of the weak links. A buddy of mine has run a 8.75 in his front engine dragster with 2000+ horsepower for years years with no issue. The real question is if you want to put in the work and time to make the 8.75 work? Or do you just not want to ever worry about it again with a heavier D60?
My guess is he's adding nitrous or boost. Most power adder cars don't need as much gear as N/A cars. Same deal with converters, a converter from a boosted combo will be tight in a N/A deal unless it's big inch, monster torque.
Several years ago I was at I-57 drag strip and saw a nice 69 Dart street car with 275 radials and GT hood. Watching him make a pass it didn't 60' very well but it was flying on the big end, it ran 6.0's (1/8) at some insane mph. When I checked it out I found it had a 588" (IIRC) wedge and was pulling 3.23 gears. That explained the soft leave and huge mph.
To the OP, call Strange and talk to them about a S60, buy once, cry once. I bought mine directly from them and other than giving them my CC number it was painless.
Sounds pretty simple you can just call and run your credit card for 2400 for a d60 and wallah it shows up at your door or you can do some legwork and get it for about 1200...
Probably the same scenario for an 8 and 3/4 but all you get is an 8 and 3/4...
When I bought mine it was around $1950 delivered. I considered going the truck housing route but decided not to. I don't have or know anyone local that has the fixtures to narrow one. The S-60 housing is lighter and it has adjustable spanners on the sides that make gear changes much quicker and easier. While I was waiting on the rear end I finished the mini tubs and relocating the springs into the frame.
How many times have you change the gears?..
I'm upgrading to a Ford 9 inch so I'll be selling the S60 out of my Duster. If you have tubs then this might be something to think about. It is 50 inches wide from hat to hat.
You can break about anything.... but odds are way in the favor of a S60 surviving your 700hp goal. The factory put D60s behind big block stick cars. These cars paled in comparison to your H.P. goals and were on a skinny rock hard tire.
...and don’t cheap out on your trans either. Chuck the stock front drum for a billet piece. That way when you shuck you’re 8.75, shock your sprag, the drum won’t explode incurring even more damage in your life. :)
Pricey.. yea, but, for me I was the “EZ Button.” My garage is jammed! 3.55’s behind a 450hp 360. It’ll live forever on the street or track. 700hp? I hope not at the hit! A rear will live longer the lighter the car is. If your car isn’t super light the torque will eat up the rear.
If the rates lower is at the big end, and the car is very light, I can see a season or two on the track.
Strange S60
Oh yea! This would be the way.
As a side note I had $1,200 total into my 8 3/4 that blew up and $1,200 total into the Dana 60 that now reside underneath the Duster..
I hear this a lot. It’s a catch 22 on cost. Ether or....
Thanks
Thanks for all your replies. I am going to just put the stock 489 in for now. Then save, save, save for a Dana. I just won't go racing till I get the Dana...
I know a guy running 9s in Dart with 8 3/4" foot brake car but its pushing it.
I have the same dillema as you and am leaning towards building Dana 60...
You can put billet caps on 489 but there will be some cost of machining involved.
