Wilwood Disc brakes stay locked when pedal released.
Well, I pushed the petal pretty forcefully like when I an staging on the two step.
I am not sure if that was the question?
Residual pressure would create a bit of drag but not hold the wheels and tire
that solid from turning.
Thank you. Yes, that answers the question. This is just my opinion. I think you will find your problem in the master or something in the pedal/ linkage that doesn't alow the pedal to fully return. You can check which it is by creating the locked wheel scenario then unbolting the master (with the lines hooked up) and pulling it away from the firewall far enough to disengage the pushrod (as suggested earlier by someone else). If this releases the brake pressure you have a pedal, linkage and or master compatability issue to sort out. If the pressure remains and can only be released by cracking the line at the master then you likely have a master problem. Good luck
I had already removed the adjustable petal rod assembly with no effect
on the pressure.
  • I believe it is the master as well.
Thanks for the sage advise.
