High pedal pressure with KH disc brakes
You're call, you can always sell off your Disk parts and go back to Drum? But I think there is really something wrong in your system OR your expectations. I can stop my 67 Dart with manual factory front disk and rear 10" drums with minimal effort. In a panic situation might use 2 feet but I doubt I would be able to react that fast.
Perhaps if you could test drive someone else car with the same setup and see if it feels different to you that would give you some data to make an informed desicion.
As for disk being better... I had my front drum fade once in a need to stop fast or hit the car in front of me situation and it was a heart dropping feeling. I was lucky that I had 12" to spare!
My first car was a '66 Satellite convertible. Manual brakes and steering, 273 2bbl, 3 on the tree. I thought the brakes were fine, but I did miss power steering.
Dana, Do you think I may have the wrong pedal to MC rod? They didn't offer the dual pot MC in '65 so parts book is of no help. Does your '67 have a single MC or dual?
Just a data point for you:
  • 72 Swinger with manual front K-H setup.
  • 15/16" Master (p/n RSD-DBMC15) -- no booster.
  • Adjustable pushrod (p/n RSD-RC14)
  • Stock(ish) rotors and middle-of-the-road pads from NAPA
I seriously marvel at how great my brakes work. The pedal travels about half of what yours does and there is a smooth and positive pedal feel. Yes, it is naturally stiffer than a boosted brake, but it doesn't take a ton of effort to stop this car quickly.
So something must be wrong with your setup. Maybe try to warranty the master and see if a new one works better? Proportioning valve? Effed up rubber lines? Stuck caliper pistons? Pinched metal line? Misajusted rear brakes? There is not a ton to the system, so just keep going through it and the problem will reveal itself.
You'll like the brakes when they are working correctly.
I seriously marvel at how great my brakes work. The pedal travels about half of what yours does and there is a smooth and positive pedal feel. Yes, it is naturally stiffer than a boosed brake, but it doesn't take a ton of effort to stop this car quickly.
Vames, Thanks for the feedback. My car is basically done except for this brake problem and front end alignment. I see you used a different MC, RSD-DBMC15, mine is a 15/16 Raybestos 36406 15/16". Also I see you're using an adjustable pushrod, that's what I needed to know. I'm using a '67 prop valve, new hoses, all new lines, no stuck calipers that I can tell, bought them a while ago but they're new rebuilds from the parts store. The car stops true, does not pull, but low pedal and a lot of leg force. I may have a bad (new MC), but when the pedal is in the rest position, I can still lift it about a 1/4" -3/8" then it stops at the brake switch. I'm pretty sure it could stand a longer pushrod. Why did you decide to use the adjustable pushrod? Were you having the same problem I have with the low pedal?
Honestly it was like 30 years ago -- most likely someone on the old slantsix.com advised that I'd need an adjustable pushrod so I put one in. Aside from adjusting it to make sure my brake light turned off at rest, it all worked fine right away, so I never had a problem like yours.
Factory dual. all 67 and up have dual masters. there are multiple lengths of push rods @Oldmanmopar posted a photo showing several side by side.
That is totally normal. also the brake light MIGHT (its that way on 67 and up) be attached to an L shaped bracket that has an adjusting bolt accessible from the passenger side of the steering column
all a longer pushrod will do is move the pedal higher to start with and then when you build pressure it will be farther from the floor. The brake light switch will have to be adjusted to compensate
JUST for a test. if someone applies the brake and all 4 wheels are off the ground and the trans is in neutral, E brake is off, check for the ability to rotate each tire. It might be more accurate to do this with a 2x4 between the brake pedal and the front seat. if the pedal is pressed too hard there will be no rotation at all. but at some point you should be able to just rotate the tires. looking for all 4 to be about the same from a force perspective. VERY unscientific test.
could the problem on these (multi KH posts) be something about the crossover tube?
restriction favoring inside pistons, or front to rear?
most likely just air
maybe remove the caliper and fill/bleed in different angles,
tap with a screwdriver handle kinda thing
also there is a hose barb on the bleeder for a reason
tube into cup (actually juice bottle), slow full deep strokes,
love it like ya mean it,
and a quick pullout, (release of pedal)
not pump it up squirt repeat
also you can bench bleed calipers when ya do the MC
(A new MC always needs turned with the ports up and a squirt or two before bench bleed)
are the slider calipers sliding on their pins properly?
were the new pads flat? and can the new pads slide along with the caliper?
did you clean the packing wax off the new front rotors? any wax or grease now on pads.
Have the rotors been correctly broken in?
do you have a brake bias? if not you will probably need one.
do you have a brake safety switch in the distribution block or master cylinder? is it stuck? and hence half the system switched off?
not being blunt.... these are all issues i created for myself at some point in the last 20 years :)
dave
Thanks much for the tips. I've read a lot about the KH conversions for early A bodies but this is the first confirmation about the possible need for an adjustable rod. There's a good deal of information
JUST for a test. if someone applies the brake and all 4 wheels are off the ground and the trans is in neutral, E brake is off, check for the ability to rotate each tire. It might be more accurate to do this with a 2x4 between the brake pedal and the front seat. if the pedal is pressed too hard there will be no rotation at all. but at some point you should be able to just rotate the tires. looking for all 4 to be about the same from a force perspective. VERY unscientific test.egarding the higher pedal
Factory dual. all 67 and up have dual masters. there are multiple lengths of push rods @Oldmanmopar posted a photo showing several side by side. This is encouraging, I've ordered the adjustable pushrod from Summit.
all a longer pushrod will do is move the pedal higher to start with and then when you build pressure it will be farther from the floor. The brake light switch will have to be adjusted to compensate. At this point that is exactly what needs to happen, adjusting the brake light switch is not an issue
JUST for a test. if someone applies the brake and all 4 wheels are off the ground and the trans is in neutral, E brake is off, check for the ability to rotate each tire. It might be more accurate to do this with a 2x4 between the brake pedal and the front seat. if the pedal is pressed too hard there will be no rotation at all. but at some point you should be able to just rotate the tires. looking for all 4 to be about the same from a force perspective. VERY unscientific test.egarding the higher pedal. I'll try it, I have a lift so easy to do.
dave
As Dana mentioned this is early KH discs, no sliding pin. I've tried 3 different sets of new pads, The set in it now (used) came with the swap meet used KH calipers, which were turned over as cores at the parts store I bought rebuilt replacement KH calipers. No difference in brake function between any of the pads. Rotors have about 170 miles on them. Yes I have '67 brake bias (prop) valve, new from Mega Parts. No brake safety switch, no light used in the '67 prop valve
Crossover tubes new, calipers seem to be pressing evenly, both. I will try the cup of brake fluid with the hose in it, I have bled the system at least 5 times, by gravity, by wife pressing down pedal close release again, and by vacuum pull from each wheel cylinder. I did bench bleed the MC, it has not run dry during any of the process. I've ordered the adjustable pushrod from Summit, gonna try that next. If that doesn't fix the issue I may replace the MC, but it is new.
This is for 1967 and up BUT it might be the same as 66 and older
Bob, please let us know your results after installing the new pushrod!
OK, so here's how it went. I bled the calipers again, several times with my wife at the pedal. She's done this with me many times going back years, we met in High School. I did get some more air out, small amounts. UPS arrived with my adjustable pushrod from Summit (see post #53). Gotta say Summit is prompt, put in the order in yesterday about 2:00 pm, arrived about noon, less than 24 hrs! Came out of Reno. Removed the old one, compared it for length and fit, put it in, adjusted it, and it did help my issue. Came with the tip on the end but made with a vinyl like clear plastic not rubber. Adjusted it about 1/8-3/16" longer than the original, and readjusted the brake light switch. pedal is acceptable now, foot pressure probably about the same but feels better with a higher pedal. The replacement rod is well made, easy to adjust in place and has "knockers" on the head for the brake switch, although my brakes switch still actuates from the brake arm. Brakes are better now but I'm still thinking about a booster.
Dana, Could you elaborate a bit about the pictures? Are you showing the brake light adjustments? The '65 is different.
One tip - no matter how much i tightened the locknut, it would eventually loosen up and the rod would slowly get a bit shorter - Id find out when my brake lights would stay stuck on. Once you find the right length, put some Loctite on the threads.
Vanes, Thanks for the tip, I happened to remove the rod over the weekend to view the back of the master to confirm bore diameter, and took some pictures of the rod when it was out. I really like the ability to fine tune the pedal height. I'll put a drip of blue Loctite on the threads when I reinstall it.
Here's a picture showing how they compare, threaded all the way in is the same length as original.
Yeah, you can lengthen that rod so the pedal is up around your nose!!! JK
just watch the height as too high and your foot can get caught under the pedal coming off the gas. In stock form it is pretty close to that.
So, '65 was the first year you could get front disc brakes on the Barracuda. The kit was installed at the dealer, not the factory. Does anyone know if the disc brake kit required the car to have power brakes? If so, was it the same booster and vacuum canister mounted on the inner fender used with power drum brakes? The boosters I see, whether original or aftermarket, are all so big that they make it hard to remove the valve cover to do adjustments. This is a big turn off for me and the reason I never planned on using a booster, but its starting to look like I will have to if I'm to enjoy driving this car. I'm thinking that if I could find an original booster and tank, that would be ideal because they take up less space than any of the later Mopar boosters as well as the aftermarket units out there. I do have an early A body booster here I bought at a swap meet years ago, and it is a monster, not sure what year it is from but suspect '69-'72.
If you go with a small booster, be aware that they take higher vacuum to operate than a larger booster. If your engine has low vacuum, you may need a vacuum pump.
It took me a long time to figure this out.
That looks like the booster for K-H fixed calipers '67+
When set up it should lower the brake pedal's initial position (at rest position)
I had one and personally didn't like it and sold it even though I liked the initial pedal hieght.
Only tip of sorts I can offer is that the vacuum bleeding with the disks was discouraged (see the Chrysler Master Tech series).
Using the tried and true methods of close and open the valve while pumping seems to work fairly well. Sometimes I can get it to gravity bleed, but not always.
I tried my Amazon pressure bleeder. I soldered in piece of copper tubing to a spare master cylinder lid. I have an aftermarket GM type master cylinder. I was pretty proud of myself till I tried it.
The GM lids won’t hold pressure, even though the clamps are super tight. Wound up with brake fluid everywhere. Oh well…..
