wiring harness temp wire connector?
Yes........ Usually in the help section, and comes with about 6in of wire. Solder it together.
Really? How about an actual answer? I'd LOVE to know how to come up with "real" connectors for these, and have not found them. If you go into Oh'Really? or NoAPA here, you get someone WHO DOESN'T KNOW WHAT a temp sender is!!!
before I moved to Tx I had friends with bone cars, even Springfield, Mo pick a part that had dozen or so old mopars. since Evans makes OEM eng harness surely they are available somewhere. I have not found any at auto pats store but not to say just didn't find them!!!!!
Worst case scenario, the stud is threaded. A couple nuts and a ring terminal.
I have seen them at Autozone in the "Help" section also.
Dorman product.
If you have a spare dash harness, cut the cigar lighter connector off and use that...
Something like this.
https://www.amazon.com/dp/B0002JN06U/?tag=fabo03-20
