alright im having a problem with headlights and dash lights flickering with the rhythm of the engine at idle also the volt reading at my battery is no more then 12.6 when the car is running and my alt is putting out 14 volts. new alt and regulator and still no change, after 2 weeks the battery gets to weak to start the car and every time it gets too weak the first thing that happens when i try to start it smoke shoots out of the carb and when i mean shoot you can hear a loud his and whiteish smoke shoots out. this is really odd after i charge the battery its fine the car starts right up with a little stumbbling then once its warmed up i have zero trouble for two weeks. this car could use a rewiring but i have rear window rust im working on and can only do one thing at a time (money is tight) any tips would help thanks
