joshl06
Active Member
I have a 360 bored .06 with iron ram eq magnum heads scat forged 408 kit that has dished pistons has 262 comp cam with 1.6 roller rockers the compression I figure should be 8.7 this is a little on the low side so I'm going to try the dreaded twin turbos I already have the t3 t04 turbos I don't have the carb yet and plan on porting the heads and going with a 507 lift cam I would like to run 93 gas and would like it to be streetable any ideas or input is welcome by the way I didn't biuld this I got it on a trade
