SirDan
my brakes were working fine for 1000-2000 miles then the other day a light changed and I needed to stop pretty fast. got on the brakes and the drivers side front tire locked up and pulled hard left. took it easy the rest of the way home. It seems like sometimes it stops great and other times it stops like the passenger front brake is doing nothing. It also seems like I might have lost some front brake fluid but currently see no leaks and the pedal feel is good.
I have brand new:
front calipers
front pads
front rubber lines
ALL hard lines
new proportioning block
new master cylinder
new booster
new wheel cylinders
new rear brake pads
new rear rubber line
I will look further for leaks more after I post this.
I have brand new:
front calipers
front pads
front rubber lines
ALL hard lines
new master cylinder
new booster
new wheel cylinders
new rear brake pads
