73Scamp318
I've torn the engine I got with the Duster down to the short block and don't want to roll the dice on the mystery cam that's in there, so I'm looking for some suggestions for a cam.
The combo is a little odd, but gearing may change down the road...
74 Duster, probably will be around 3200 with driver
360 .060 over
Speed Pro H116CP60 pistons about .005 below the deck
stock stroke, should be right at 10:1
OOTB Edelbrock RPM 60779 heads
Edelbrock RPM Air Gap
Holley 750 DP or Vac Sec, I have both
it'll have cheapie 1 5/8" Hedman headers (that's what I already have)
2.5" pipes, Hooker Aerochamber mufflers
TF 727
9.5" PTC converter (brake stalls at 3500 behind my warmed over, low-13s 318 )
8.75 with 3.23 sure grip, tire size undecided yet
I'm looking for mid-12s out of it, but I realize it may not happen with those gears. It needs to run on pump 93 and I'd like to have some lope, but I don't want to over-cam it.
Lunati suggested their Voodoo 60403 268/276-.494/.513 and I had someone suggest the Mopar 292-.508 cam. I'm leaning towards a bigger cam because of the converter, but I'd like to get some input.
360 .060 over
TF 727
Share
