New Sm Block Milodon stock height, hi capacity, street, pro touring, road race pan!!!
autoxcuda
I've been helping/bugging with Milodon on a small block Mopar pro touring/high capacity-stock height/road race pans similar to the other road race pans they make. Like the big block Mopar one they offer, pn 31580. Many people use that big block road race pan on their HiPo street cars to get a pan that does not go past their K-member and get smashed, but still has increased capacity and advanced oil control. This pan is actually a little shorter than even a stock pan for ultimate low ground clearance situations!!
It just took about 2 years of needling Milodon to do this, so I want to get the word out and support thier efforts. I see a lots of lowered cars with deep pans just waiting to get smashed loose all their oil.
These 318/340 and 360 pans just came out last Friday and available NOW!: http://www.milodon.com/oil-pans/road-race-oil-pans.asp
One of the requirements I felt for this new pan was fitting A-bodies as well as B and E bodies. And the toughest requirement was fitting the super-duper tight 73-76 A-body spool K-member. The spool motor mounts create a wall of K-member right down the bottom of the pan. So we tested the pan extensively with a 73-76 K-member with full steering linkage. TTI headers and header that go behind the steering linkage will not be a fitment problem. Just fitting the pan to E and B bodies would have been easy, but the A’s would be left out.
Of note: The current issue Mopar Muscle Magazine 427cid stroker small block by AndyF (AR Engineering) was tested in Tim Werner’s red 68 Valiant hitting 130+ at Portland International Raceway’s road course. The Valiant and motor could keep up with new Z06 Corvettes until motor’s new custom Charlies oil pan lost oil pressure and they had to go home early. AndyF was about to make pan himself, but I told him to wait for the new Milodon SB pan and one is on its way to Oregon right now.
I have also ran dry on oil in my Barracuda with a just a stock pan at the track. My car was not anywhere near as fast as Tim’s 68 Valiant. Stock small block pans have NO BAFFLING whatsoever. Most big block Mopar HP and a lot of non HP pans have some baffling front and rear. None for any small block, ever. My new 416 stroker SB WILL have this new Milodon SB pan.
Point is, any somewhat serious pro touring or suspension mod car you should think about protecting the motor with a baffled pan designed for high sustained G’s.
Any well thought out additional baffling will help a stock small block pan. But there is a glass ceiling to that. And it’s not very high. The Milodon pan will take you to the limits of a full on vintage road race car and have you covered and covered for future mods.
Now, this pan is a serious handling, road race piece. Some of the features of this NEW pan:
  • Side pods for 6 quarts of oil
  • FIVE trap door/gates
  • 3 braking deacceleration gates to keep oil around the sump under hard braking
  • 2 lateral G gates
  • fully baffled sump for complete oil control
  • false right angle wall at back of sump to keep oil from very rear of pan. Also allows more centerlink clearance for possible lowered motors.
  • fully TIG welded construction
  • over 45 years of SCCA road race proven sump design features in this pan.
  • Made right here in USA
This pan should not need the band aid of an accusump reserve system. Unless of course there is a weak link somewhere else in the oiling system. I know $450 is a lot for an oil pan. But look at a $200 drag race pan with the bucket welded under them. Then look at all pictures I took of the gates, ledges, baffles, custom sump, weld quality, construction quality of this Road Race pan and I think you will understand some of the $$$ differences.
These new small block pans will be on display at Fall Fling October 30, 2010 and SEMA
The pan is $321.95 @ Summit.
Sorry, that's a different pan. That's sounds the Milodon pn 30936/30941 Street Strip 7 qt pan that sits a little more than 1/2" deeper than this new pan. Great pan for going in a straight line and increased capacity without hanging too much below the K-member on the street.
This road race/pro-touring pan is:
pn 31590 for 318/340
pn 31595 for 360
This picture shows the depth of the new pan. It's in there. It's just hidden behind the K-member!!! This is a straight on picture.
Works really well for really lowered cars.
Hey Steve, That is great news! Thanks for your efforts in getting Milodon to build this thing. It looks to be everything a road racer would need for an oil pan!
I have a question about a different oil pan that I currently have on my 408,
what do you think of this pan for road racing duty? Take note, I do not have the factory K-frame, but the AlterKation.
http://www.hughesengines.com/Index/...cw==&level1=T2lsaW5nIFN5c3RlbQ==&partid=11168
Flatlander has it for $370 + $120 for the oil pick-up tube.
http://www.flatlanderracing.com/oilcirclechrys.html
That's a different pan too. That a circle track pan that is a rear sump. It will not fit a stock K-member. It's designed to fit circle track tube chassis that would normally fit a chevy rear sump pan. That pan does not show up on the Milodon website. It may have been discontinued and Milodon just used the old part number. But still it's confusing....
Email being sent to Milodon. :clock:
Nothing against Moroso, but it's a drag pan. That's it's intended purpose. It says so in the description. It also sits 1" lower (8.25") than the factory pan compared to the new Milodon Road Race pan (little under 7.25"). And because it's rear sump behind the wheels that might be a bigger issue. Does it sit lower than your headers?
That Moroso has only two trap doors just for only acceleration. It has one bent horizontal baffle across it. The Milodon Road race creates 6 baffled compartments with 3 gate for deceleration and 2 just for side load G's. The rear false wall, baffled/walls on the sump floor, and shelf hold oil in acceleration. Your car isn't set up to do wheelstands and trans brake launches?? So the deceleration gates are more important on a road race pan.
Here's a Moroso road race pan: http://www.jegs.com/i/Moroso/710/21900/10002/-1?CT=999
Dang it, Steve! Now you've gone and taken all the concern and worry out of having a low-hanging oil pan!
Seriously, great job working with - and pestering - a known manufacturer of quality components to come up with a superior part for our A-bodies! Now all I gotta do is start saving up even more pennies for another must-have part.
Nice pan, Thanks for the pics! How does it fit the early a K member? The corners are rounded and to fit a Kevco pan I had to notch the K member. If that fits early a's it will be awesome.
My educated guess is yes. I took some measurement off a 66 Barracuda. But I can't find the pictures. The area of concearn would be the idler mount to the passenger oil sump kickout.
Anyone in So Cal got a 63-66 K-member, centerlink, idler and V-8 motor mounts to borrow?
Here is the prototype and the final pan. This was one of the tightest pan fitments the owner of Milodon has come across.
Here's some pics I took this weekend of a 66 Cuda. But it wasn't up in the air so I could get tape measurement off it like I did before.
Looks pretty promising. Your thoughts??
That is good to know b4 I ordered the wrong part. I will wait until summit/Jegs and others stock them so I can get the best price... No rush..... Great work with Milodon BTW!! Thanks a MILLION from many of my friends and I..
Brian
Steve, have you tried any of TTI's headers??? I don't think they'll fit as they hug a straight pan.
What exhaust type's have you tested fitment with??
Brian
Oh no no this jeep doesn't play in the dirt, it embarrasses the sport cars.
Im thinking the pan won't clear the diff though, i'll have to get her on the lift tomorrow...
Also you should use the Milodon windage tray. The factory small block might not work and the louvers don't allow for as much oil return at the Milodon. And the Milodon one with thier main studs allows you to adjust the tray for differrent strokes so you can dial it in for maximum effectiveness and performance.
Just to make sure I can feed this pan. I smoothed out the oil pump and rear main passages so as not to get any turbulence and aeration in the oil.
Keep this up pal and I'm gonna have to hang your picture next to the one of John Wayne in my garage.
HaHaHa, thats good!
seriously, I saw the pan on mopax, nice work Steve. that pan is a nice piece and guaranteed one will find its way onto my valiant. I'm still gonna keep the accusump though... cheap insurance and great for cold starts after the car has sat for ages like mine is right now.
So you have to commit to $700+ headers or stock manifolds to run this pan, right?
as in no headman/hooker/flowtech yadda yadda.. are gonna fit this pan?
Show some pics of the milodon facility, that'd be nice.
