sbh126
Well I tore the head off my recently aquired 63 valiant 4 door with 170 slant 6 and found several large chunks missing from the #6 piston. Goes to show you how rugged these little monsters are. I'll post some pics of the damage later on tonight. So I am in need of a slant for what was supposed to be my super cheap play car. I called a guy that says he's got a couple slants and I will be going out there to get one today. What do I need to look for? Can I still do a compression test if the engine is cold/dry? If so how much pressure should there be? I do not plan on rebuilding the engine. other than the gaskets and maybe shaving the head down a bit. maybe a new valve train. Also can I use a 225/904 out of a truck? I found a good deal but I'm not sure if the 904 had any major differences When used in trucks. Any help is appreciated.
