68Valiant440
Im looking to buy a new set of BB Chrysler heads..
I have new shortblock stroker being built and was gonna use some Eddy RPM heads.But I called Indy about thier 440EZ heads and Russ told me i was gonna lose around 100 hp if i use the small Eddy head.The motor is under 500 cubes and around 11.0 with the 84cc rpm heads.The rpm heads are only 210 intake runners and 2.14/1.81 valves and 84cc chamber.The Indy 440EZ heads are 270 intake,2.19/1.8 valves and 75cc..so my comp will be alil higher.
I read some bad things about Indy on here and now cant decide if buying thier heads are a good idea.
I was shopping around and saw that the Eddy Victor head will fit,but need off set rockers and then i went on TTI headers sight to see that i would need a motor plate to clear the headers with stock mounts.I will be installing this in the 68 Valiant(a body) in my sig.
I also see that Pro Comp has a nice CNC head i can use too,but dont see any real tech info about intake and exh locations that might stop me from buying them.
I will be using a TTI 2" header and have Crane Cams Gold 1.6 rockers and a custom hyd flat tappet cam around .600"
So any thoughts or answers to a good head that has stock locationt o accpet my headers/rockers etc? Also will be running a Victor intake..Not max wedge style tho..
So is Indy good or junk? Pro Comp..Junk? Eddy Victor will they work with my headers and schumaker motor mounts?
Thanks
Adam
Thanks
Adam
