Fabrication Thread: What have you made?
Hey, Donnie very cool stuff I'm willing to bet if you fabed the steering collar alot of guy's would buy them, cuz when you switch over to the floor shift you need the smooth collar. Someone correct me if I'm wrong, but I think 67-69 A is the same as 67-69 B body. Also the gas cap adapter works great I have it on my '69 Valiant and it's perfect!
Larry
Larry
I started down that road. Its pretty expensive, but I may pick it back up. I may have a better solution soon regarding the manufacturing. If I do make em' this will be the place they make their debut! LOL
I have a thread regarding the evolution of that part. I found out that the manual steering columns are kinda hard to find, not to mention its a PITA to change the entire column. I have designed this so you can fit the plugs through it. You dont need to remove the column in order to install it and it uses all the factory switches, bearings, etc.
I may have to drag it outta the dirt..
Rallye instrument panel that accepts a D.I.N. head unit. The support plate may not look like much but it is/was the most difficult piece I've designed and fabricated so far.
Using fiber optics to backlight the legends on these bezels is running a close 2nd.
:worthles:
Throw some pics of that stuff up here!!! :smile::smile::smile:
Backlighting project isn't complete. I will post a pic of a early effort but please dont hijack this thread by suggesting LEDs, E.L.film, etc.. Thanks
O.K so the flip top adaptor creates an air tight seal at the gas cap is how I see it. So the tank would then need venting,if not already done.
Most of that has been covered in the original thread. Please see the thread specific to the adapter. (link in my signature)
Lets try to keep this thread to the Fabrication. ;-)
Hi all I do some fabrication also, no CNC stuff other than a plasma. Here is a pic of a bumper i did
i usually fab up stuff for vw, bajas and rails. Here is a link to the stuff i make. STUFF
Im getting ready to build a gauge cluster for my barracuda, though.
Console I designed for my Dart
Ha. I made this little guy in 20 minutes. Adapts a new solid state voltage regulator to be bolted in place of the factory mounting provisions for the mechanical one.
mech. unit bolted in factory location:
Bracket out of 1/4" thick aluminum:
Simple, yet effective. :)
A few things, Rear bumper with tailgater lights and front bumper.
Back in 1997 I designed this work station called the KillerKart and had them made here in the U.S.A. The Inflite' killerKart, so versatile it can be put to work in 30 seconds from storage form and put in the trunk of your car and virtually lay flat. I sold many KillerKarts to mechanics, pinstripers and other artists..
This is one of the many I designed over the years there.
here is my 10 h.p. 4 speed radio flyer. its not done yet. but getting there. i made the mount for the master cylinder today.
and my pride and joy. my blown slant six.
