Best nasty running LA low buck builds.....
Abodybomber
Breaking street machines , since 1983.....:)
Legendary Member
Arroyo grande ca
360,home ported heads,1.88/1.60 valves.Ultra Street Beast(Crower) hyd. flat tappet,223/234@.050.Re-ringed short block.72 Dart,2800 stall/4:10's Ran 12.80's@108/09,ton of tire slippage at Sacramento.Would love to hear,similar combos.
not really all that fast but it was cheap.
68 318
untouched heads had 20 thousandths shaved off with heads assembled still
steel shim gaskets.
340 grind cam. .454 lift
eddy performer rpm intake
650 holly
home ported 318 manifolds with choke butterfly taken out and holes tapped and plugged.
2 1/2 in. duel exhaust dumped at the rear.
904 trans with transgo shift kit
3000 stall
3.55 gears
245-60-14 bfg tires.
car went 13.70 at 99mph was my daily driver. beat the living piss out of that engine for 3 yrsand it just kept going. had less than a $1500 in the whole engine. sold it for $1200 and my buddy put it in a dakota with a 150 shot and it went 12.90s for two seasons till it fried a piston.
Mild 360,KB flat top pistons9.9to1 comp,Small Ultradyne flat tappet cam,home ported J heads,small headers,performer RPM intake,750 DP,904 with 11" 2800 converter by PTC,3.91 gears,71 duster 3100lbs ,full exhaust system,11.80's @115mph. 8" PTC converter,4.30 gears 11.40's. Daily driven to work,kid to private school,etc. and race tracks as far as 100miles away.
Another that I like. 1996 360 magnum purchased from a salvage yard in 2000 for $350.00. Added unported Magnum R/T heads(paid 300.00 new with Rev stainless valves),mild Bullet hyd roller grind,upgraded valve springs,thin head gaskets,china RPM style intake,750dp,PTC 9.5" converter,3.73 8.8 rear in a 1989 Dakota,was my daily driver and even towed a car and motorcycle when I moved 700miles away. Sold it to a friend some years ago and he still daily drives it and races it around the area. Run's 12.20's on motor and 10.90's @123mph on a 150shot,has for 4yrs and never hurt a piston or head gasket. It weighs 3550lbs with the driver,I'd bet in a 3100lb abody with 4.10's and a looser converter it would pick up and run 11.50's without much trouble.
D-1 procharger
340 forged steel crank
Custom cut flat tappet cam
M-1 intake
8 to 1 compression
Ross pistons
Carb shop blow through carb 750
360-2 Indy heads mildly ported
Billet main caps
Carrillo rods
Made 694 hp on dyno 630 lb/ft torque at 19 lbs of boost
Put in 69 dart, got 3/4 of the way down track, sheared the left axle off and put the car in the wall. Slid through the traps raking the wall at 12.07 at 61 mph.
It was heartbreaking. It was in my friends car and I ended up with the motor now for my 65 dart.
Like that little Dakota! My brothers got an 03 R/T that's tricked out a little bit but we want to make it a ripper but our beautiful state of California sucks when you want to make some hp because of stupid *** smog!
Gold, did not know ,you did Magnums.Will,p.m. you soon.I am at a crossroads.
360 .040 over 9.75 comp.
$130 Ebay Sealed Power pistons and rings
polished stock Magnum crank
lightened, polished, Magnum rods with used once ARP bolts
596 heads milled .050" with used 1.88 MP valves and cheapo 1.6 Milodon exh. valves
heavily ported 235 cfm intake / 170 cfm exh.
used 926 Comp springs locks and retainers
.484 MP cam used one season
match ported late 70s 360 iron intake with square bore adapter
used oil pump, timing chain, reworked junkyard distributor
750 Holley DoublePumper 1.75" Hooker SuperComps
442 HP @ 6000 460 TQ @ 4700
7.5 @ 89 1/8 mile 11.8 @ 111 1/4 mile
3400# Duster
904 8" 4500 stall 4.56 gear 28x10.5 slick
hoping to break the 11.5s this weekend
I don't know how Dding a super charger is cheap or a full rebuild is cheap.
Lets keep it to bolt on's and a cam change only. Re-ring is exceptable as cheap if y did it yourself.
Gear, suspension etc... Changes and upgrades allowed.
How does that sound?
Theres hope for my build yet
318 with stock pistons
Comp xe268 cam
302 heads bowl blended with 1.88/1.60 valves
.028 head gaskets
Holley 600
Performer intake
Hooker headers
2 1/4 duals through flowmaster 40's
2000 stall
Comp xe268 cam
.028 head gaskets
Holley 600
Performer intake
Hooker headers
2000 stall
depending on gears and tires your combo if in an a-body should get you into the high 13s low 14s. more stall would help your combo.
100k 360 - with a re-reing & re-bearings
kb 107 flattops
stock 1.88 intake 587 castings
mopar p4452992 - 474 lift cam
eddy dual quad tunnel ram
(2) holley 390's
stock 904
dynamic 3800 stall converter
3.23 gears
in a 3430 lb 66 cuda
ran 12.56 @106 - 108 was my best mph so far but not on ther 12.56 run
1.74 60' time
360, 040 over, stock crank, eagle floating sir rods,10:5.1,comp push rods, rpm air gap intake, hughes rockers, tti headers, holley red electric pump, electric fan, fully ported 2.08/1.60 eddy heads, holley ultra 750 double pumper. lunati hyd voodoo camin it right now. switching to a solid flat soon. a lunati 30200913 or 30200741. havent desided witch one yet, i need help picking right one for the job. im swithing the 373s to 410s and putting in a 3000-4000 stall. any suggestions?? trying for 520 or so hp.
70 swinger with 72 360 x heads(70)compleatly
Gone through roller rockets solid lifters holley750 do
Hooker headers KB PISTONS 9.5/1 eagle rods stock crank monster cam
Intake(70) DUI ignition (hei) A-833 4spd 3:55 sure grip dyno 470hp /440lb
Torque STOUT $3850 thanks Mike petite Petite race engines New Milford Ct if you can't beat em you can't beat em
358"
iron w2 hogan heads
10.7.1
aluminum rods
750 alky
power glide
782 lift solid roller
9.1 at 145
on nitrous 7.20 @ 188
225" mike boss chassis dragster
Stock '83 318 out of a stick shift shorty van.
MP 220 @ .020 .455" cam
Home ported heads with stock size valves.
Recurved stock electronic distributor
Performer 318/360 intake
TQ off a '73 440
A-body stock exhaust manifolds
2" daul exhaust.
10.5" clutch and O/D A833
In a '70 dart I bought for $200
Goes real strong but have not timed it yet. Might have $1,500 in the whole car. The quintessential $200 beater!
How the hell is this low buck!
358"
iron w2 hogan heads
10.7.1
aluminum rods
750 alky
power glide
9.1 at 145
W2 heads, aluminum rods and a roller cam arent really cheap parts.
Low buck is stock iron heads, cast pistons, flat tappet cam, tossed together for under 2K in my opinion.
supercharger can't be low buck? what is the price range here?
'71 340 .30 Over(traded for the block)
TRW Pistons(used)
untouched (for now) J heads
509 Purple Shaft(used)
Victor 340 Intake(used)
650 Holley(new)
Have about 1000 in the engine.
ok, i can see that.. but for what it runs its a pretty low dollar build for a damn near 6 second car..
ROFLMAO
That ain't cheap no way no how on any planet except the billions moon. Come on now.
