Single turbo 360
Mounted bov,Devils own water/meth injection. Finished exhaust with a 3.5 Dynomax ultra flow muffler. Boost comes in about 3200 rpm @ 6 pounds total. Dont have a total cost. Still working on it? added a hose thru radiator support to get some cooler air.
Yes, thank you SO much for the details. I'm still thinkin'..................
Looks good. You might want'a "not" wind things up right before shut down. I saw your other vids, what was the best you ran "no" turbo? Bet you're anxious to see the difference.
Do your run power steering or do you think there's room for a pump "down there?"
I like how simple this thing is. No complicated headers, no intercooler. If i some day build turbo engine I will follow this route.
There's another very similar, Google "topfueldart"
So how much was the cost for the little add on??? I'm interested in doing the same...
Thanks.......................PETE................
Made it to track this weekend and Destin made some passes on the dart. Picked up 8 tenths and 9 mph with 6 psi. Afr was still a little rich at 10.8 with meth injection. Best pass was 12.62 @109 2.009 60 foot
stock dist locked with msd btm pulling 1 degree per 1psi. with water/meth 36 and 32 without
1/4 mile pass[ame="http://youtu.be/zRq9XVWGwz8"]http://youtu.be/zRq9XVWGwz8[/ame]
[ame="http://youtu.be/BIBCDzf6NWQ"]http://youtu.be/BIBCDzf6NWQ[/ame]
Thanks for the update. I'm really getting interested in this
wow, i like it! The sound alone makes me smile.....:D
You want to push it a little with higher boost pressure? Does an engine like this can stand around 15-20psi?
Thanks for Info!
Michael
