440outlawdart
lisa has a 100 lbs on her bumper,and her car is a small block,needs lots of hp,high stall convertor,transbrake,and a good hooking car and good track prep
You will probably need a lot of weight in the trunk. One of the guys that I race with runs almost the exact same ET as my car, but pulls 2-3 foot wheel stands on a regular basis (mine just pulls the wheels about 6-12 inches now). This video is of Danny Black driving Jamie Fenner's car at the US Nationals in Stock Eliminator....yes, that is a 340 in that 3400# car....I think he hung the hoops a little too high on this one.
2007 US Nationals Danny Black wheelstand - YouTube
This must be the wheelsup73 and Lisa Caldwell Dart. Lots of video on youtube, looks like it's running a four link. I like it! Although I was hoping to stay with caltracs.
I know a lot of drag cars running weight in the rear. I've personally never tried it.
https://www.youtube.com/watch?v=zd3TadLVg9E
I run ladder bars. I have 50#s in the trunk as well as a 10 gallon fuel cell and 2 group 65 batterys that weigh 45#s a piece. 4.56 gears in the Dana and 2.77 first gear in the 904 trans with a continental 5700 8 inch converter and a turbo action brake. My motor is making around 575HP and is 11.7 to 1 410 stroker with a solid Hughes cam 276/280 @ .050 631 lift and Edelbrock heads. My car weight is 51.7 % front heavy and the car weighs in at 3160#s. I would start with 100 lbs in the trunk and see what it will do. I took alot of time and 2 oil pans to get it where it won't come down hard from a wheelstand and hurt parts. Good luck with it. Here is a vid of how Lisa's car use to leave before I got it to drag the bumper. This vid is the 3rd shake down run with the new stroker motor in 2007.
http://youtu.be/l2CggdLuLPc
I believe Ron's Valiant had #90 welded into the back bumper...that definitely helps with putting the car up on its *** when launching lol
I think that would be a blast! Running 10's and carry the front wheels out to the 60' beams.
What do I need suspension and/or H.P. and torque or both? lol...
Here is what I'm working with 65 Valiant post mini tubbed and cage.
Hover a couple inches off the ground for 59' and you are in the money!
65 Valiants have an inherent disability when it comes to carrying the front wheels farther than a few feet. So I think you should just sell me that little red Valiant and be done with such foolishness.
The reason we don't dial out the wheel stand is that every time up to the line we always get a lot of mike time and my sponsors get mentioned.
Last time out are package was .017,018 and .021 in Super Pro.
Ladder bars,big tire's,3800 rpm converter,493 400 block engine.
No weight in the trunck.
2 battery's and 2 gallons of fuel in a 10 gallon fuel cell.
60 ft when we hit the cone with the front tire's on the ground 1.19 to 1.21
In the air 1.45-1.47
60 Ft Cone.
