So I'm finally ready to get a different width of tire an rim. I am running 275-60-15 by Goodrich on 15x8 with 4.5 back space. i've done some measuring today an have a total of 14 1/2 inches from the inside well to the inside fender lip. And from the tire mounting surface on the drum I have 6 1/4 inches to the inside fender lip. It looks like if I can run a 12 inch rim with 7 inch back space I should come out with about a 1/2 inch of clearance on both sides of the tire. This is on a 68 dart with a mini tub an spring relocation. I skimmed through the 325-50-15 forums an only found one dart but had the rear narrowed to get the deeper look. Are there any others here with this tire under a dart? And did u run into other problems getting them to fit? I think I can put these tires on a 12 inch rim. Its been hard to pony up for new rims an tires when I already have the ones I have but the tires will just spin when I get on it an I intend to take it to bandimere this summer. Fingers crossed.
Oh the rims I already have are weld draglite, an the wider one I intend to get are going to be weld Draglites. there where a lot of dusters with this sized tires that I found, but I just didn't find many darts. Thanks again.
