draginmopars
after pulling the 540 to put in the green dart
finally got to see if the 6 would fit
first changed the trans from a fixed yoke to a slip yoke
trans came out of an Airport Tug
Used the trans mount to locate the engine front to rear
eng/trans was moved back 12" in it's past life
Surprised how easy it went in
removed the p/s, vacuum pump, and A/c >> not needed
now just have to make motor mounts
then pull it back out
make some engine mods, clean everything up/ paint
