rod7515
Im starting to plan my rewiring of my 66 Dart project. I'll be moving the battery to the trunk and rewiring everything out under the hood. I bought new terminals for the bulk head connector as well as wire. I've gotten some good suggestions from a few members so far. I was wondering if I am missing anything as I plan what I want/need to do.
I will be adding a disconnect switch in the trunk as well. I am no wiring guru but I should be able to work thru this. I know its not a one day job. Thus the reason to start planning ahead! So here's the additions I think I need to add. Relays to operate the fuel pump, dual electric fans, Headlight kit, ignition box. I'm sure I am missing something. I will be adding an addition fuse panel for the relays. I haven't figured out if I can put the relays up under the dash or if I need to put them in the engine compartment under where the battery used to be. I would also like to put the coil and ignition box underneath the dash as well. I am thinking the fuel pump relay could go in the trunk closer to the fuel pump instead of with the other relays. Anyone have any suggestions or thoughts of a direction I should look into or a circuit I am forgetting.
Thanks Rod
Thanks Rod
