WSUTARD
I need help figuring out this problem. Changed my intake gasket, now the engine won't start. I'm getting spark, blue color. Pulled the plugs and I could smell gas on them. Waited a day just in case I flooded it.
I think it might be the timing but I'm not sure. I marked the distributor shaft and the block prior to pulling it so I know it's at the same timing. I forgot to mark the rotor position so I tried it at both rotor positions. I also made sure it was pointin at the #1 plug when the timing mark was showing at the block markings.
I didn't mess with the carb but I'm also not sure what to check on it.
Any thoughts before I tow it to the shop?
