Wiper Motor Interchange List with part numbers/years/body styles...
1970dartcustom
of the Moore clan
Broken Arrow, OK
1970dartcustom submitted a new Article:
Wiper motor interchange list with part numbers/years/body styles...
Part#/Stamp# Year-Yr Body Speed Remarks
2525629 1964-66 A VARIABLE
2525270 1964-65 B SINGLE
2580915 1967 B VARIABLE
2584975 1965 C VARIABLE
2586988 1966-67 C 2/3 SPEED
2587697 1968 B 3-SPEED LATE
2770090 1968 C 2-SPEED
2770090 1969-71 A 2-SPEED
2770090 1969-70 B 2-SPEED
2770147 1966-67 AB VARIABLE WHITE SW PLATE PARTS
2808767 1967 AB VARIABLE LATE ALUM/BLACK PARTS
2808767 1968 B 3-SPEED EARLY ALUM/BLACK PARTS
2808801 1966 B VARIABLE WHITE SW PLATE PARTS
2808801 1967 AB VARIABLE WHITE SW PLATE PARTS
2822252 1968 AB 2-SPEED
2822962 1967-68 AB VARIABLE LATE ALUM/BLACK
2822963 1966-67 AB VARIABLE EARLY WHITE SW PLATE
2822965 1967 B VARIABLE
2889982 1968 B 3-SPEED LATE PARTS
2926919 1969-71 C 3-SPEED PCDY
2926929 1969-71 C 2-SPEED
2926929 1970-71 E 2-SPEED
2926929 1971 B 2-SPEED
2983033 1969 B 3-SPEED EARLY
2983116 1969-71 A VARIABLE
2983116 1969 B 3-SPEED LATE
2983116 1970 B 3-SPEED
3004112 1968 C 2-SPEED
3004114 1968 A VARIABLE
3004114 1968 B 3-SPEED LATE
3431077 1970-71 E VARIABLE
3431077 1971 B VARIABLE
3431531 1972 A 2-SPEED UP TO 6/5/72
3431532 1972 A VAR-3SP
3431533 1972 BCE 2-SPEED UP TO 6/5/72
3431534 1972 BE VAR-3SP UP TO 9/1/71
3431535 1972 C VAR-3SP
3431605 1972 A 2-SPEED AFTER 6/5/72
3431605 1973 A 2-SPEED UP TO 2/1/73
3431606 1972 BCE 2-SPEED AFTER 6/5/72
3431606 1973 BCE 2-SPEED UP TO 2/1/73
3431624 1972 BE VARI-3SPD AFTER 9/1/71 BLACK CAP
3431665 1973 BE VARI-3SPD
3431666 1973 C VARI-3SPD
3431718 1973 BCE 2-SPEED AFTER 2/1/73
3431730 1973-74 A 2-SPEED AFTER 2/1/73
3431780 1974 C 3-SPEED
3431790 1974 BCE 2-SPEED
3431905 1974 A 3-SPEED
3431906 1974 BE 3-SPEED
3620877 1973 A VARI-3SPD
Read more about this article here...
If you take a look at the top or engine bay side of the wiper motor. There are three (going from head) phillips screws that you can loosen. Simply line the mark on the top plate with the locations listed in the photo and then your 3 speed wiper motor works with any of the labeled body styles.
As far as I remember these are the right locations. The pictures from rick eherberg (sp?) But no longer posted so I had to recreate from memory. The A body spot is correct as I used a c body motor on my A
Is there any more detailed info on this procedure anywhere that you know of? I appreciate your help...
If I find another wiper motor I can takes pics as I do it. It'd very straight forward though.
I have never seen the info any where else on the net. I believe it was on mopar style I found the info from. But when I went to get the pic recently it was gone :-(
Factory service manual apparantly has it.
Not the pic I recall but similar answer.
I could take pics of doing it with a junk 3 speed I have floating around (if I didn't scrap it)
It's a very simple procedure.
The pic below has the locations needed
According to my 1974 Chassis Service Manual, the above drawings are not quite correct. I purchased an NOS three-speed wiper motor for an F-Body that I will be putting into my Duster. The illustration below from my 1974 manual shows the correct locations. I added the location for the F-Body as that location did not even exist on the pre-1976 wiper motors. The second pic is of my NOS F-Body motor. Notice that it is still set up for an F-Body car. I added callouts to show the locator tab positions for E/B, C, and A Bodies. Notice also that the E and B Bodies use the same tab location.
Wiper Motors found on 1967 Model Year A-bodies.
2822 930: Variable speed. Green, Red, Blue, Brown at connector
2770 137?: Variable speed with variable speed switch; 3 wires atconnector
2822 962 : Variable speed ? with variable speed switch; 3 wires at connector
2822 962 : Variable speed with two speed switch; Red, Blue, Brown at connector
2822 963 : 2 speed, white switch plate, 2 speed switch; Red, Blue, Brown at connector.
Photos here: Wiper Motor Wires
Wiring for some of the above.
Just for people like me that are cheap, I recommend buy a Cardone 3-speed b-body motor part #40-370. My ‘67 Barracuda used the early style arm and pivot bushing. I simply swapped to the late sixties, early seventies a-body 3-speed arm and bushing and re-clocked the gear cover as posted above. The Cardone motor cast about $80 from Summit and appears to be fairly well rebuilt.
Here’s the thread.
Wiper motor swap
