Oldschoolcuda
Early-A Body Nerd
My 65 Dart is finally running.
ThanksYea, yea, leave it just like that.
Congratulations.
I like that motor! My 273 sounds good but not like that.
What a great sounding 273!!!
I'm getting ready to pick up two 273's, ones a short block and I would love to build one like yours. Did you have a build thread or a list of specs on here somewhere? Your 273 just sounds healthy.
Thank you so much. I know the short block I'm picking up is the lower compression 273 and I don't know if the long block is a Comando spec or not but it will be. Thanks again and your engine video sound is great on my PC speakers but I'll bet much better in person. Congrats on the build.Stock spec. 1965 273 commando bottom end/block notched, 1965 273 heads ported and modded with 1.88 & 1.60 valves and lunati springs.
Lunati #30200740 cam( around .520 lift). 273 adjustable rockers.
Oldschool offy intake manifold matched to heads. Edelbrock 1406 carb.
Pertronix ignition.
J&R fenderwell headers.
Good afternoon,
Great duration on that fresh idle! Just curious if there are any hp#s' on that unit?
C.
