j par
Well-hung Member
I'm hearing ya zinc. I'm trying to think of what the call for it is here?
Zinc before "running it".
Before you fire the engine make sure that you have the zinc stuff in your engine oil --> will definitely help during break-in to protect your cam and (flat tappet) lifters.
never quit protecting the cam/lifters. I add ZDDP Maxx to a couple of my flat tappet cars, and one I have on VR1-10w-30. I never quit protecting.This is my point for askin why?? Same low lift cam and lifters thats been in the motor for the last 35000 miles.
An oil change is still something different than starting a reassembled engine. I guess that needs all the protection even with well used parts.Drove it and did oil changes with regular oil for 14 years
Yes, Jeff. A while ago, I actually called Valvoline themselves, and talked with their tech. They said if a car with flat tappet cam already has, per say 50,000 miles on it, it should survive without special oil/additives.When I owned my Stingray, I didn't know about this....
Drove it and did oil changes with regular oil for 14 years without ANY problems. ...
I would NEVER do that now....
Jeff
AAAAAAAHH I get it NOW.... "Sorry Honey.... Some FOOL on FABO said it would probably be fine without ZDDP additives. That idiot...Sorry that we have to get a new cam now..."Are you guys saying I could run the risk of flattening this crap unknown cam and lifters and run the risk of having to get something better? Oh the horror!
I'm not saying you will............
Do you look down the barrel of a cocked and loaded gun to see if there is a round in the chamber?? Not saying the gun will go off if you do........
Lack of imagination is what killed the Apollo 1 astronauts...............
What, where, when, how you wish to do it, good luck!!
simple fact of life! wanta flat tappit cam to life you run ZDDP in ya oil! or go roller cam that dont need it! if you want a new cam bbuy one dont kill that cam just to justify buying a new cam! imagine all the fine metal cam particals covering all them parts you just cleaned!!
